![]() | Home > General > Rear window defroster/demister not working. 3500 EUR NEW! |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
I think you need to remove the upper boot spoiler.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
I certainly would not take their word for it. An hour with a multimeter will quickly determine whether the screen is faulty or whether it's something else such as the connector behind the tailgate spoiler. 2012 SDV6 - it's missing a couple of cylinders
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Agree with Wayne on that one, way back main dealer said they had thoroughly checked front screen out on mine as one side not working, and needed new screen at £600.00+ turned out to be £1.25p fuse blown so much for their expert diagnosis.
Googs Member Since: 04 Oct 2022 Location: Greens Beach Tasmania Posts: 89 ![]() ![]() ![]() |
If there is a bad connection that can not be fixed surely you have a part out yards where you are that you can get a second hand tailgate from...hopefully one that the rear demister works in. |
Unless it's deep in the loom, the only connection is the plug that connects tailgate to car. The bonded in screen might lose a wire or two across the screen but it's pretty rare to lose the whole lot.
