Home > Technical > At my wits end after body off 😪
looneyfitter
2005 Range Rover Sport TDV6 HSE Alaska White
Guys n Gals any help please?
Ive recently had the body off to change the heads on my 2005 rrs 2.7.
Now im getting gearbox faults. Essentially no low range.
Checked with iid and the code im getting it p0902-00 clutch actuator circuit low.
Car drives great and changes gear fine but hdc etc doesnt work.
Also theres a fair bit of play in the steering now. Ive checked the UJs which are fine? But the lower slip coupler is loose. Shpuld theree be some sort of plastic sleeve between the 2 to take up the slack? If so, do i order rhe lower part or the upper? Cheers😶
Post #630414 Sun Jan 29 2023 7:54pm
looneyfitter
Im thinking ive poss left a connector off.or bent.a pin? Which connector do i check and can it be done with a 4 post lift?
Post #630415 Sun Jan 29 2023 7:55pm
I think there are 3? plugs on the transfer case (middle or car, pass side)
Post #630416 Sun Jan 29 2023 7:58pm
looneyfitter
Really not sure mate thought id put them all back on 😪
Post #630418 Sun Jan 29 2023 8:17pm
The transmission loom runs down the center of the car, appears in the engine bay at the rear middle. (one with foil on I think)
and then must get plugged in behind the battery and to that ecu.
So unplug and replug in
Post #630427 Mon Jan 30 2023 12:22pm
