Home > General > USB-C in dash power source & recomendations
PC76
Hi all,
I have installed as Mous window mount with charging for mi phone as I need to be able to see the screen when I'm out and about and I'm looking for a switched power source to pull off enough power for it to be able to charge. it has a USB-C connector on the lead which I have routed behind the dash to the top of the centre console. what I need is the best wires to be able to tap off from and also recommendations of a unit to use so I can plug in the lead from the mount.
I have Late 2015 L494 which is built to the MY16 spec if this helps...
Hoping you guys can point me in the right direction.
Thanks 2015 4.4 Autobiography
2010 3.0 HSE 162K - Gone
Post #630400 Sun Jan 29 2023 9:53am
Googs
Australia 2012 Range Rover Sport Supercharged Autobiography Fuji White
Something like this be okay for your needs?
https://www.amazon.com/KEWIG-Charger-Adapt...P/ref?th=1
Post #630515 Thu Feb 02 2023 3:34am
