Home > General > C pillar interior trim removal
nation1
United Kingdom 2005 Range Rover Sport TDV6 HSE Baltic Blue
I need to remove the c pillar trims inside the car, the lining has come away and I need to repair them, how do I remove these ?
Thanks Ross
Post #630312 Thu Jan 26 2023 10:59pm
karlos01
if you mean the ones near front screen
pop the range rover badge off you will find a size 10 torx screw un do that and the pillar should pop off be careful as the airbags are located behind there
Post #630332 Fri Jan 27 2023 3:37pm
nation1
Hi, no it’s the ones just behind the passenger seating. Thanks
Post #630333 Fri Jan 27 2023 3:38pm
Any airbag markings will have torx behind them.
Then just pull it away.
Post #630335 Fri Jan 27 2023 4:59pm
Could be a good Time to run a wire between the boot light and reading light to make them come on when doors open.
Need a diode or two as well Mods: FaceLift/D4 Sat Nav Display and reverse camera. BT. Remote FBH. Parking light switch position. Rear reading light activated by doors.
Post #630337 Fri Jan 27 2023 5:07pm
https://drive.google.com/file/d/1V52ryTfwl...share_link
Post #630342 Fri Jan 27 2023 8:58pm
Stevepd
Cheers Col.
Ross let us know how you get on and in particular what and how you reglue the material. My D pillar trim is also starting to lift at the edges and is on this year's to do list.
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #630349 Sat Jan 28 2023 7:22am
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
Echo what Stevepd says. I have the same issue. Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #630350 Sat Jan 28 2023 8:03am
Nothing better to do so added the extra A-D trim pages.
https://drive.google.com/file/d/1eY-_0bdmU...share_link
Post #630351 Sat Jan 28 2023 8:11am
