Home > Technical > Heater issue
AIJ 615
Heater issue
Hi everyone
RR Sport 2010 HSE 3.0 V6 and owned motor an out 2 months now. So yeah earlier today was bitterly cold outside and so I out the heating on. The driver side is warm at best and the passenger side is cool. Thank good for the heated seats but I’m feeling disappointed.
The water in adequately filled with coolant and the climate control is on 28 for both sides
Any ideas ?
Post #628960 Thu Dec 08 2022 9:23pm
Disco_Mikey
Guilty for heater matrix blocking up on these
Post #628961 Thu Dec 08 2022 9:44pm
AIJ 615
Ok so what exactly is that and can it be easily corrected ?
Alan
Post #628963 Thu Dec 08 2022 9:54pm
iforland
Very very common...the Land Rover book states that you have to remove the centre console and large parts of the dash (if not the whole thing!!) to remove the internal heat matrix.
However there are some alternatives you can try...
1. If you have the type of matrix that has metal clips that connect the pipes to the matrix you can cut out a small piece of plastic and then slide the matrix out to replace it or flush it out --- This is what I have done, there is a guide somewhere that shows you how to do this.
2. Flush the system, in my experience the standard connect hose pipe up or adding of flushing additives do not work. However I'm going to try using a central heating pump with descaling solution directly connected to the pipes as demonstrated in this video
https://www.youtube.com/watch?v=LtnVyFNyU1w
Post #628969 Fri Dec 09 2022 10:48am
AIJ 615
Post #628970 Fri Dec 09 2022 10:50am
iforland
I found the message that shows the short cut method to get the matrix out:
https://www.rrsport.co.uk/forum/topic42040...eater+core
Post #628971 Fri Dec 09 2022 10:55am
AIJ 615
Update
Yeah so I think it’s deffo the matrix thing as the air is slightly warm at best and that’s only from the drivers side front and back, I’ve closed the vents off from passenger side as they are cold - Infact I’ve shut them all off and just rely on heated seats.
How much would it cost to get this fixed if it was the matrix ? Main dealer or specialist garage.
I’ve little to no experience self DIY. The engine temperature remains consistent at normal operating temp smack in middle of the temp gage on dashboard
Al
Post #629001 Sun Dec 11 2022 10:37am
Alexdc12
United Kingdom 2009 Range Rover Sport 3.0 TDV6 HSE Java Black
If it helps, i just bought the part at that was £142 but i will attempt to fit it myself. I am a little gutted though as the pipes dont have the join in that i was expecting Sad I will have to cut and join with some heater hose i think
Post #629356 Thu Dec 22 2022 8:58pm
Themoog
United Kingdom 2005 Range Rover Sport Supercharged Rimini Red
Our 05 L320 supercharged had no heating from the passenger side a while ago. Our local garage had it in to sort and they ordered a new matrix but the one that arrived had much longer connecting pies on it which would have meant most of the dash would have to be removed.
In the end they disconnected the heater pipes in the engine bay and back flushed it which solved the problem. I would imagine it's a similar story with your vehicle.
Post #629363 Fri Dec 23 2022 8:05am
AIJ 615
Diagnostic machine connected and I get this error code
B1081-00 (6Cool Left temperature damper motor
The RRS 2010 goes in Wednesday for a service and also they going to have a look at this issue. If it is the left temp damper motor is this a big job ?
Any thoughts ?
Post #629895 Sat Jan 14 2023 4:00pm
