![]() | Home > Technical > 2005 Upper Tailgate Trim Part Number? |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
Hi,
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
https://new.lrcat.com/#!/12129/118992/119198/9483 Regards etc.,
Thanks @TheWojtek. The diagrams helped a little but I think I've found the part number. I THINK it's DRC500011. Barrie.
My bad, I somehow thought of the inner trim, not the outer one. You are right, obviously, that's the number you've found. This part is often changed for the "2012 look" trim with a metal stripe. Regards etc.,
No problem. Thanks for your time. Barrie.
