Home > Faults & Fixes > Headlining RRS L320 |
Toonraider Member Since: 15 May 2022 Location: Newcastle upon Tyne Posts: 95 |
Hi
Fri Nov 11 2022 5:34pm |
Michael997 Member Since: 31 Jan 2006 Location: Worcestershire Posts: 227 |
It is the hard liner that is loose the fabric is fine, sorry I didn’t explain it clearly
Fri Nov 11 2022 6:29pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4992 |
I have to admit mine never seemed overly secure either, the parts list only shows a couple of plastic clips at the rear edge lining which are attached to a bracket bonded to the headlining and then push into a bracket on the actual roof panel. The workshop manual makes no mention of any other clips that have to be released on the lining itself to remove it from the car. So not really sure what secures it around the sunroof area if anything, as mine does not vibrate, flex or make any creaking noises at all that I noticed never really bothered about it much.
Fri Nov 11 2022 10:54pm |
Thank you Col, it seem to be loose where it meets the rear of the sunroof, I will open the roof today and see if I can get an idea of what is allowing it to move 🤞🏻
Sat Nov 12 2022 7:10am |
Here is one option to download the various sections, but if you do a search for workshop manual download quite a few different options will come up. I do have a pdf copy of the 12/13 owner's handbook I put together if you don't have one already.
Sat Nov 12 2022 8:20am |
Thank you
Sat Nov 12 2022 9:20am |
I discovered the edge of the headlining to the rear of my sunroof was held up with self adhesive Velcro pads less than an inch square, I managed to apply some thick superglue to the pads that had separated from the roof of the car and applied pressure for about 10 minutes which seems to have worked, so easy fix 🤞🏻
Sat Nov 12 2022 1:08pm |
Must remember that if mine gets any worse or if I get the urge to have another look.
Sat Nov 12 2022 7:17pm |
Googs Member Since: 04 Oct 2022 Location: Greens Beach Tasmania Posts: 89 |
I looked at my Headlining today and it seem to be the same, maybe that's how they are. |
Wed Dec 07 2022 6:54pm |
