![]() | Home > Maintenance & Modifications > Leisure battery under bonnet L320 |
Dc191peter Member Since: 19 Sep 2022 Location: Bodmin Posts: 7 ![]() ![]() ![]() |
Hi all, I want to install a leisure battery in my 2013 RRS but there are two electronic modules in the ‘battery tray’ in the offside wing area under the bonnet. Can these be safely relocated or has anyone found another suitable spot for a second battery. Many thanks. 2013 RRS HSE Black Edition |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
The Disco 3/4 had a Aux battery option, might be able to utilise the brackets etc. from one of those to reposition the ecu's and wiring to make space to accommodate a battery, only a suggestion as not sure how much difference there is under the bonnet that side between the Disco and L320.
The D4 also had the option to fit a Aux battery which fits quite close to the air filter, although they are quite small capacity batteries at 15Ahr/200amp 150mm L x 90mm W, you could probably squeeze one into the L320 but personaly not sure it would be worth the effort.
Thanks for the responses. I belong to a 4x4 Response group and want an auxiliary battery for amber LEDs, a matrix and led floodlights. The current draw would be quite small so I may try to fit a compact battery with a split charger and see if that works. I’ll let you know. 2013 RRS HSE Black Edition |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
The 15Ah battery in the D4 was, I think, for the stop/start system but if you can get a battery of that size and it fits both the space available and your needs then that's the way to go.
Thank you, the D4 battery will be perfect for my needs as the LEDs draw very little power. 2013 RRS HSE Black Edition |
cassman Member Since: 09 Nov 2020 Location: Essex Posts: 71 ![]() ![]() ![]() |
If you get it working I'd be very interested in how you did it.
Nearly done. Will post pictures when finished. 2013 RRS HSE Black Edition |
