![]() | Home > In Car Electronics > BCEM location needed ! |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
I would guess they meant the BCM or as its known on the landrover CJB which is the fusebox behind the glovebox.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
I think the L/R BeCM term went out with the old P38, I assume you mean a warning light of some sort, as there a quite a few on the sport it might help if you said which one, as there could be numerous causes for one to illuminate.
FarmerColin Member Since: 19 Oct 2022 Location: Devon Posts: 2 ![]() ![]() ![]() |
Ref my post - I hope that I am replying correctly, I am no au fait with much on the internet
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
What garage are you using? Is it a specialist LR place? 2012 SDV6 - it's missing a couple of cylinders
