![]() | Home > Wheels & Tyres > Winter Tyres and 18inch Wheels |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
I think your options for 18" rims for the sport are very limited even more so if you have 6 pot brembo calipers on the front, I believe there are some available although not genuine L/R, I think they may be also somewhat expensive just to use as a winter wheel/tyre. I would of thought your best option would be 255/50 x 19" which are the recommended L/R size and a lot more readily available. H rated tyres have a speed rating of 130mph so wouldn't have thought that would be a problem as that is the rating L/R use for winter tyres.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9025 ![]() ![]() ![]() |
No LR 18inch rim will fit a 2011 I believe. There are a couple of aftermarket providers that do wheels that fit but they're not a cheap option.
tr51 Member Since: 02 May 2021 Location: UK Posts: 5 ![]() ![]() |
Perfect, thanks both!
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 ![]() ![]() ![]() |
I've just put my winter wheels on my TDV8. My car is a facelift model from 2010, the year when LR dropped Brembos from the TDV8, so IIRC it has the same standard brakes as yours. The smallest OE wheels that will fit are 19 inch and so when I first got my Sport I found a set of OE 19inch RRS wheels. I've been running Nokian 255/50R19 and very happy with them. They still have 6mm tread after four winters use.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
If you have Brembos, there are only a couple of 19" options, the below in picture being one.
