![]() | Home > General (L494) > Cheap Load retaining system |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 469 ![]() ![]() ![]() |
Oops didn’t mean to download upside down |
Managed to get 1 photo turned the right way round. Not easy to do at all…. |
Great idea |
Yep simple yet effective. I store it just under the parcel shelf at high level so it’s out of sight when not in use. It’s spring loaded so once set to correct size by twisting it you just push the inner and outer pole together to release and re fit it. It also extends far enough to go into the recess on the right side of the boot if needed. If it had a Land Rover badge on it it would be £100……. |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 260 ![]() ![]() |
Shower curtain pole!
Yeah basically. They advertise it as a curtain pole as well. |
