Home > Wheels & Tyres > Tyre pressure monitor
AIJ 615
Gents
Just been thinking (before anyone says it , yes it did hurt lol)
I had a slow puncture the other day and ended up replacing the tyre however just dawned on me that I never had no pressure waring come up, what do I need to do for the tyre pressures to be monitored ?
I have a RRS 2010 HSE
Post #627005 Sat Oct 01 2022 7:17am
It was a factory optional extra, don't bother retro fitting it I have it on mine, it's better than nothing just, all it does on the L320 is flashes a amber warning light if a particular tyre pressure drops by 25% that's it, it doesn't tell you pressures or anything like that, does manage to tell you which wheel though. I would try and find a good quality aftermarket one.
Post #627013 Sat Oct 01 2022 8:25am
AIJ 615
Ok cheers
And how can you tell if you have this fitted ?
Al
Post #627020 Sat Oct 01 2022 1:59pm
If you have it, it will come up on the dash as to whether it is set for light or heavy load when the ignition is switched on and it's going through it's system checks.
Post #627035 Sat Oct 01 2022 6:04pm
AIJ 615
Ok thanks Col, yeah I’ve not seen that so guessing I don’t have it
In the words of ‘Homer Simpson’ DOH !!!!
Post #627043 Sat Oct 01 2022 8:29pm
