Home > General (L494) > Help clunking when stopping
3hcp
Can anyone help identify a clunking noise when stopping my RRS, happens when I’m slowing down to say 5mph could be suspension, anti roll bars, gearbox or even the deployable side steps?
H 2015 RRS DIESEL HYBRID
Post #626827 Fri Sep 23 2022 8:04pm
Farmer Chalk
Is it clunking from suspension ? Or the rear of the car…
Early L494’s. Suffered from fuel surge in the tank which caused a clunking noise.. this was cured on complaint to the dealer network by foam inserts .. had mine done which cured it.. only a thought seeing yours is a 15 plate..
If it’s from the front of the car check the front suspension .. the bushes at the front of the lower arms fail.. these should be oil filled. If you can see any fluid leakage around these bushes then they have failed allowing the lower arm to move slightly backwards causing the clunk at lower speeds.
Post #626832 Sat Sep 24 2022 7:52am
3hcp
Seems to come from under n/s seats so I’m thinking anti roll bar bushes, I’ll try that first a it’s a simple fix. 2015 RRS DIESEL HYBRID
Post #626833 Sat Sep 24 2022 8:48am
3hcp
It was the lower suspension arms as you suggested 2015 RRS DIESEL HYBRID
Post #627351 Thu Oct 13 2022 2:53pm
