Home > Technical > L320 4.2 v8 supercharger MOT fail
karlos01
failed mot today here is the list
would a blowing manifold gasket cause the idle failure?
Post #626656 Fri Sep 16 2022 12:05pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Very possible but start looking for a vacum leak 1st and check long and short term fuel trims
Post #626659 Fri Sep 16 2022 2:55pm
karlos01
spoke to mot tester he said the emissions test was showing it running to lean
Post #626660 Fri Sep 16 2022 3:13pm
where did you get it done? halfords?
Post #626661 Fri Sep 16 2022 3:15pm
karlos01
engine management light was on I took it off but these fault was stored
Post #626662 Fri Sep 16 2022 3:16pm
karlos01
🤣🤣🤣 local garage up road from me
Post #626663 Fri Sep 16 2022 3:17pm
Lrstaylor
I would still be looking for a vac leak
Post #626673 Fri Sep 16 2022 10:15pm
karlos01
I'll have a look around over the weekend
Post #626675 Sat Sep 17 2022 5:30am
karlos01
can the sport breaks system be bleed like a normal car or will it have to be done by diagnostic like the p38 ?
Post #626689 Sat Sep 17 2022 5:29pm
I think it depends on how much of the system you have disturbed, if just replacing fluid or fitting new flexi brake pipes etc. can be done the old method with a jar and tube, pressure bleeder or vacuum pump etc. If the hydraulic control unit etc. has been removed, replaced for example I believe it has to be bleed via diag. equipment to I assume open various valves/solenoids. I am in the near future about to change the fluid and renew the flex pipes on mine so did read up on it a bit. As a point of interest when I replaced the accumulator and steel brake pipes on my old P38 certainly never connected it to any diag. tool to bleed the system.
Post #626695 Sat Sep 17 2022 9:10pm
karlos01
thanks for that it both the rubber hoses from the front callipers that failed
got them just got to put them on
nothing eles on the break system has been touched so should just be a normal bleeding process
Post #626696 Sun Sep 18 2022 5:20am
karlos01
quick update took the rr for a long drive on Saturday put it in command shift left it in 4th gear (at the advice from a mechanic) to get the cats hot 30 mile round trip parked it up left over night
started it yesterday and the engine light has gone off popped diagnostic on and it not showing fault as running to lean
suspect with all the short runs it been doing the cats might of been a bit sooted up
Post #626706 Mon Sep 19 2022 7:24am
if you can look at live data with a diagnostic tool;
look at the long term fuel trims. If they are getting close to 20% (or in double figures) then the light will probably return.
disconnecting the battery for a few hours should reset the trims
Post #626707 Mon Sep 19 2022 1:49pm
karlos01
thanks for that I'm just waiting for chap with diagnostic to let me know when he free later to do a live check on every thing and see what the readings are
Post #626708 Mon Sep 19 2022 2:43pm
karlos01
update
got the break pipes sorted EML came back on showing running lean on both banks.
done live check both lambada sensors showing 1V.
but MAF (delphine brand) is dropping in volts when the revs get up thinking this could now be causing the light to come on as on inspection it looks like it never been replaced from new.
Post #626847 Sun Sep 25 2022 8:14am
