Home > General (L494) > Overheating - on power not idle |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 |
Hmmm, we’re working on a 3.6 TDV8 L322 at the moment. No typical signs of blown head gasket, but the coolant reservoir has CO2 getting into it. It pressurized the cooling system to the point it blew the upper tank seal. Car has plenty of power, but overheats at higher speeds. Get them to do a CO2 test on the coolant reservoir, if they haven’t already. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Fri Sep 02 2022 2:51pm |
leehud74 Member Since: 11 May 2020 Location: Manchester Posts: 3 |
OK will do thank you. Could a leaking radiator though be the cause of the over heating? if a stone for instance has ruptured the aux radiator, creating a leak, would the loss of water pressure result in perhaps the water pump not operating efficiently to cool the engine? |
Fri Sep 02 2022 2:58pm |
