Home > Technical > Intermittent 'Restricted Performance' Error
Josh95
Northern Ireland 2012 Range Rover Sport 3.0 TDV6 HSE Java Black
Every so often whenever I start up the car, I get this alert. It's only the yellow triangle, and the performance of the car doesn't seem to be affected.
I've took it to an indie where they ran diagnostics - but they couldn't find anything wrong with it.
Just wondering if anyone else has had this problem? I find that whenever I turn the ignition on without starting the engine immediately, it is less likely to happen. It usually disappears whenever I restart the car after a journey.
I originally thought it was the battery, so I replaced it but the problem still persists.
Should I take it to a different indie or what could be the issue?
Post #626299 Sat Aug 27 2022 10:46am
jases4x4
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
When i had this message it was my front two pipes split, common issue. Check them its the top 2 coming from intercooler to engine.
Post #626301 Sat Aug 27 2022 1:34pm
Josh95
Will have a look! Was it must of a hassle to fix?
Post #626302 Sat Aug 27 2022 2:27pm
NoExpert
Two totally different engines.
It’s not recording the error message so may need real diagnostics with data logging to see what the sensors are doing. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #626304 Sat Aug 27 2022 2:49pm
