Home > Technical > Drive shaft
ShooterNeil
Drive shaft
I have had a clicking noise when going round islands for the past few weeks so I ordered a new driveshaft from GKN and fitted it this morning only to find the noise is still exactly the same as it was before
could it be CV joints on the front prop shaft the rear prop is new and the UJ’s were very notchy on the old one
FRONT Brake discs and pads are new and not catching the stone guards
Any ideas
Thanks
2011 5.0 supercharged sport 61 AB 5.0 supercharged rocket
07 HSE TDV8 with lots of toys EGR removed BAS remap
56 HSE WAS FULL OF PROBLEMS
Post #626090 Fri Aug 12 2022 5:45pm
NoExpert
Did you check the axles? Sound like this would be more likely than a prop shaft. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #626103 Sat Aug 13 2022 2:52pm
