![]() | Home > Technical > 2012 RRS steering / suspension |
Seatown Member Since: 15 Mar 2019 Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands Posts: 100 ![]() ![]() ![]() |
It might be the DSC kicking in. It applies the brake to the wheel it thinks is slipping and the ABS unit can make a noise like that. You should see the DSC light flash on the dash but sometimes it happens so quickly you have to be ready to look out for it.
