Home > Faults & Fixes > Passenger footwell panel removal
Autobiography1969
range rover sport 2012 passenger footwell panel removal,
I have a rogue wire missing from the front passenger side footwell,
when I removed the light to replace the bulb that has been out for
a long time, the wire disappeared into the panelling, I cant reach it,
so the panel will need to come loose or off to find it..
Any how too's?
Thank you in advance.. ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #625685 Mon Jul 25 2022 11:19pm
Do you mean this one?
https://www.rrsport.co.uk/forum/topic59574...t=footwell
Post #625686 Mon Jul 25 2022 11:39pm
Autobiography1969
Perfect as always Col..Thank you ===========================================
Post #625697 Tue Jul 26 2022 10:46pm
Autobiography1969
As always with me, I have finally got round to looking at this and your instructions are perfect,
I have almost completely removed the lower glove box section with the small carpet bit
attached, just left the side attached near the bonnet lever,
I can see everything, except a wire, does the wire come from the carpet side or the left,
I guess the only other place this can have disappeared to is actually under the floor carpet??
Instructions if anyone else stumbles across this thread looking for help,,
"If I remember right, two small turnbuckle screws just below bottom edge of lower glove box lid, grab the small piece of carpet trim attached to the panel by the transmission tunnel and give it a gentle tug there is a hidden spring clip behind it, should then be able to lower panel enough and wiggle it out, if you still can't get it right out you may have to remove the piece of footwell trim by the bonnet release lever should then drop straight out." ===========================================
Post #633396 Sun May 28 2023 9:57am
Comes from the left, should be small black plug/connector with a black and a purple wire fitted, as normal L/R don't give a lot of spare wire but should be there somewhere Smile
Post #633397 Sun May 28 2023 10:51am
It has to be the most difficult bit of trim to refit !
Post #633398 Sun May 28 2023 11:34am
Autobiography1969
Thanks Col,
I will have another look at some point, the wife isn't too worried
so neither am I in a rush, I will look at some point,,
Andy K,
I was either lucky or this wasn't as bad as you would imagine,
not sure about digging too deep if I cannot find the plug next time I look.. ===========================================
Post #633400 Sun May 28 2023 3:01pm
This is the wire you are looking for, takes me longer to get down into the footwell than it does to get the trim off. Laughing
Post #633403 Mon May 29 2023 4:01am
Autobiography1969
That's great Col,
I am sure I will be able to find it next time
I get in there, the location looks maybe a little
further left than maybe I was looking..
Bow down Bow down Thumbs Up ===========================================
Post #633416 Mon May 29 2023 5:37pm
