Home > Technical > Rear left stays high
Sween23
United Kingdom 2008 Range Rover Sport TDV6 HSE Rimini Red
Hi all,
My rear left always stays around 20mm higher than the rest of the car. I have the iid tool and even when I recalibrate the suspension within 10 mins of driving it returns to being around 20mm higher again.
The only fault that shows up is C1A20-64
What could this be?
Thanks Arron.
Post #625585 Thu Jul 21 2022 7:51pm
NoExpert
Could be a faulty sensor. Coupled with that error I’d also look at removing the valve blocks and cleaning them and possibly rebuilding them (new o rings).
Can the IID tool operate individual components of the suspension system? In JLR-SDD you can operate each valve, the compressor, raise or lower each strut, etc. makes it a little easier to diagnose problems. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #625595 Fri Jul 22 2022 6:53am
Sween23
thanks for your reply.
I was thinking possible a height sensor but wasn't sure.
I'm not sure regarding if the IID tool can operate individual components but I'll give it a try 👍
Post #625605 Fri Jul 22 2022 10:38am
