Home > General > 3l Petrol Any Good? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5007 |
The Australians should be able to tell you.
Tue Jul 19 2022 6:26pm |
Dartanjang Member Since: 07 Jan 2018 Location: Mälardalen Posts: 6 |
Intriguing, I must say. So there seems to exist this rare car in Sweden. I never knew that 3l petrol was available. When I check the ad and the registration data with the transportation authorities, both state the same 3l petrol. The company that sells it is some ways away from home but now I really want to see this car in person and hear the explanation to this mystery. |
Wed Jul 20 2022 6:41am |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1849 |
Might be worth asking on the USA site https://www.rangerovers.net/forums/range-rover-sport-ii-l494.43/ 2023 P440e SE Dynamic on order -cancelled
Wed Jul 20 2022 7:33am |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1176 |
The 3L SCV6 is basically the AJV8 with two cylinders blanked off.
The one thing to look out for is the dreaded crossover coolant pipe failure - that's about the only 'weakness' on these engines. On a MY14 model, it's ripe for replacement now. Quite a few in ZA as well, although not as popular as the SCV8. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Wed Jul 20 2022 7:47am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 |
I knew the D4 had this engine - some show up time to time in Australia but I did not know the RRS was also fitted with it - found this UK article.
Wed Jul 20 2022 11:51am |
^ yep, as I said in my earlier post, it's just the AJV8 with two cylinders blanked off, so not much weight savings.
Wed Jul 20 2022 2:51pm |
I guess Jaguar were tight to do the job properly with a dedicated V6 rather than a cut down V8. 07MY RRS TDV6
Thu Jul 21 2022 4:15am |
