Home > Technical > Restricted performance
CT777
United Kingdom 2011 Range Rover Sport SDV6 HSE Stornoway Grey
Good morning
I have a RRS SDV6 2011, car is running absolutely fine until i accelerate hard then i get the red triangle stating restricted performance.
I plug my gap tool in and clear and all is well again but this has happened 3 times now, the code i get is P22D4-13 (2F )
Turbocharger turbine inlet valve position sensor circuit- general electrical failure.
Can anybody advise me please, do i need to do anything or is this leading to something more sinister.
Thanks in advance
Chris
Post #625335 Mon Jul 11 2022 9:00am
Disco_Mikey
Quote:
The engine control module has determined an open circuit via lack of bias voltage, low current flow, no change in the state of an input in response to an output
Turbine intake valve position sensor circuit open circuit, high resistance
This is the valve on the back of the secondary turbo. We've see a few go faulty over the years, but worth checking continuity between the sensor and PCM first, as it's not a cheap part...
Post #625336 Mon Jul 11 2022 9:42am
CT777
Mike
Many thanks for the response, when you say check continuity do you mean see if this continues to happen when i accelerate hard ?
If so do you have a rough idea of cost please
Regards
Chris
Post #625337 Mon Jul 11 2022 9:54am
Disco_Mikey
Continuity of wiring
Post #625338 Mon Jul 11 2022 10:30am
CT777
Mike
Thanks again, wiring certainly not part of my limited knowledge.
I will see what my local indy makes of it should it occur again.
Regards
Post #625339 Mon Jul 11 2022 10:38am
