![]() | Home > Technical > Air Con problem |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9026 ![]() ![]() ![]() |
Could be a fault with the blender doors in the unit in the dashboard. If they're stuck you could be getting minimal cold air mixed in to the flow. 2012 SDV6 - it's missing a couple of cylinders
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 331 ![]() ![]() ![]() |
Thank you for yours! Can you give me any advice as to how I can check to see if that is the problem? In your option should I be receiving VERY COLD AIR if the system is working correctly? Andrew Kennedy |
