Home > General > Warranty question - coolant issues
bermyandy
2013 Range Rover Sport Supercharged Zermatt Silver
Out of interest, has anyone here had a coolant leak firstly from the oil cooler, repaired, and then shortly after a coolant leak from the thermostat?
I have an ongoing case with Land Rover as my argument is they are the same piece of work/claim, but Land Rover of the view everything was done right the first time and therefore the second repair is entirely seperate
Post #624658 Mon Jun 06 2022 12:47pm
AdyP
United Kingdom 2007 Range Rover Sport TDV6 HSE Lugano Teal
Hi. I had a mysterious coolant leak.
Couldn't locate it anywhere. Then saw on YouTube the plastic thermostat housing was a weakness. It drips onto the manifold and evaporates so hard to detect. Also oil in my coolant. After fears of a head gasket I saw again on YouTube that it was more like oil cooler. Had the oil cooler replaced and at the same time the leak on the thermostat housing was discovered. Both fixed at the same time but were separate issues I'm afraid.
Post #624659 Mon Jun 06 2022 2:38pm
