![]() | Home > Maintenance & Modifications > Rear light condensation |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
I used a hairdryer on mine last year on not too hot a setting. I held it close to the lens and was sure not to hold it in one place for too long. I did 5 or 6 sessions of around 15mins each over 2 days. Not had any condensation in there since. Barrie.
Isn’t it in the manual that says to expect this, so actually normal. 2006 2.7 TDV6 HSE in Cairns Blue. |
Paulsinhis30s Member Since: 12 Jan 2018 Location: Wiltshire Posts: 20 ![]() ![]() ![]() |
Might be what you did anyway but just to be belt and braces, take the light unit out and remove the bulbs before using the hairdryer so that the condensation can escape. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
Condensation is normal. The light units are vented and so you can get some damp air in them at times. It goes away with time. 2012 SDV6 - it's missing a couple of cylinders
Srg70 Member Since: 09 Sep 2017 Location: Surrey Posts: 17 ![]() ![]() |
It has been there for months now and although the moisture has (mostly) gone it has left a white/cloudy stain inside. 2015 RRS SDV6 HSE Grey |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 ![]() ![]() |
Hi,
Thanks, looks like I’m replacing them. Very poor design if that’s the case. 2015 RRS SDV6 HSE Grey |
