![]() | Home > Technical > Powered tailgate won't close! |
Stu2012RRSAutobiography Member Since: 07 Apr 2022 Location: Manchester Posts: 2 ![]() ![]() ![]() |
So sorting out the first problem on my newly acquired 2012 Autobiography has provided a new issue. The strut bracket on the body had bent backwards causing the strut to rub against the bracket causing the strut to pop off the bracket every 4/5th time the tailgate was opened. I acquired a replacement strut off ebay (AP Premium) and fitted it whilst i waited for the new brackets to arrive (from Lithuania - non available in UK!). Everything worked fine, then I replaced the bracket a couple of days later and it wouldn't close on the button and hasn't since. Tried the tailgate height setting procedure, keeping the close button pressed to set and no chime.
