Home > Faults & Fixes > EPB help
amgmaj
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
EPB help
Hi Everyone
Need some help for my friends 2006 RRS this afternoon we changed the driver side rear wheel, jacked the car up quite high until the wheel lifted of the ground it was higher then normal when changing a wheel, anyway once all done and jack removed it was still sitting high from the rear so we moved the car suspension up and down all back to normal height again and then I pushed the EPB started getting all sorts of squeaks and noises coming from the rear of RRS was perfect until changing the wheel, how can we fix this problem any advice, help please?
One more thing I managed to release it using my Gap IIDtool after a few tries and the squeaks, noises fixed but then went for a drive around the block and the EPB problem came back again Big Cry
All was fine until the wheel change.
Thank you
Post #623870 Tue Apr 26 2022 8:03pm
