Home > Technical > RRS 2005 n/s door not locking
bricky0
Hi everyone i have a problem with the passenger door lock on my rrs 2005 problem is the door does not lock at all on the key fob or on the dash lock switch if anone has encountered this problem any help or info will greatly appreciated and is there a manual way to lock the door
Many thanks
Post #623585 Fri Apr 15 2022 7:02am
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Pretty common issue, I've done the wife's D3 drivers door twice now. Same issue same part here you go
https://www.ebay.co.uk/itm/FOR-RANGE-ROVER...635-2958-0
Post #623587 Fri Apr 15 2022 7:25am
To manually lock press the leaver next to the door release pull.
As said, very common for the motor latch assembly to fail
Post #623593 Fri Apr 15 2022 9:42am
