Home > Technical > Advice about a broken tube, causing my 'performance' issue
Stephen@bham
United Kingdom 2013 Range Rover Sport SDV6 SE Java Black
Hello all. I'm new to the forum and would like some advice please?
I have an RRS SDV6 2013 for the last 4 years and absolutely love the car.
I have had a warning saying 'restricted performance' for around 3 of the 5 times i've used the car in the last few weeks.
Usually when i push the car around 2500 revs. If I stop and turn off the car for a couple of mins, no warning.
After looking on the net for answers and thinking the worst, i opened up the bonnet and under the cover i found a tube split.
I thought I may just be able to pull the tube out and replace it, when it snapped.
As I'm not sure if the tube is fixed to the rubber and how the rubber fixes to the 'engine?'
Will i do more damage if i try pulling the tube out ( does it actually pop out of the rubber ) or is the tube/rubber a complete connection?
Would anyone know what this tube and connection is called, what its used for and could it be causing the 'restricted performance' issue?
I've added 2 pics which show a distant and close up view.
Thank you in advance for any advice.
Post #623581 Thu Apr 14 2022 9:18pm
Only a guess but looks a bit like crankcase oil breather/separator pipe to me, but sure someone will know.
Post #623583 Thu Apr 14 2022 9:49pm
Disco_Mikey
Oil separator, as above
I doubt this is causing your issue, as the latest inlet manifold have these ports blocked off...
What fault codes do you have?
Post #623586 Fri Apr 15 2022 7:02am
Stephen@bham
Thank you for your help.
I’ve attached a photo of the diag code.
Post #623595 Fri Apr 15 2022 10:20am
MREXIANI
Italy 2012 Range Rover Sport 3.0 TDV6 HSE Lux Orkney Grey
Hi Stephen
Please check all vacuum hose connections and that all control valves are functional
Regards
Post #624097 Sun May 08 2022 5:36pm
