Home > General > Steering wheel judder but not wheels out of balance
Kev H
United Kingdom 2008 Range Rover Sport TDV6 HSE Bonatti Grey
Can anyone advise me what to look for to replace to stop the steering wheel judder over 50 mph and on a motorway a tendency to wander which means constant slight steering adjustments, I have had the front tyres replaced and balanced and moved front wheels to back in case I have a buckled wheel but still the same any help would be appreciated , Thumbs Up
Post #623322 Sun Apr 03 2022 7:55am
Dave B
If you have odd tyre wear, for example signs of sideways scuffing across the tread, it may be your wheel bearings.
They're hard to check by normal means, but in my case once the bearing was off, it was obvious it was knackered.
New bearings and wobble went.
Dave 2010 3.6 TDV8 HSE (Gone)
Post #623323 Sun Apr 03 2022 8:53am
Disco_Mikey
Front lower wishbone bushes are a favourite Thumbs Up
Post #623324 Sun Apr 03 2022 9:14am
Grimble
Wandering on a motorway is not unusual, blame poor quality road surface and ruts, especially in lane 1. RRS HSE Dynamic SDV6 2014
Nemo mortalium omnibus horus sapit
Post #623354 Mon Apr 04 2022 10:57am
daxmatt
Wishbone bushes
Post #623371 Mon Apr 04 2022 6:46pm
Crraigymmmmm
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
w/bone bushes! Mine were "ok" and passed MOT but I tried everything, New tires, alignments, check wheels for buckles,
When I took the bottom arms off the rear bushed were shot badly. polybushes and another alignment and all sorted!
Post #623426 Thu Apr 07 2022 2:16pm
Puslinch
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Same here, bushes cured all vibration, shutter, and creaking. 2018 Telsa MS
2012 Range Rover Sport HSE+
1990 Porsche 944
1985 LR 90 Soft top V8
Post #623434 Fri Apr 08 2022 7:23am
Devon Z
I’m hoping wishbone bushes will cure my similar issues, though mine manifest themselves with braking also at strange times namely downhill or on the motorway. Symptoms just like warped discs but they are brand new and brake smooth at low medium speeds.
I get no knocks, rattling or squeaks from the front suspension at all.
I’ll get and replace the bushes at some point but I’m recovering from a crushed middle finger on my right hand which precludes spanner work for the moment 😞 Steve
1998 Volvo V70 R auto FWD, mothballed future project.
Post #623600 Fri Apr 15 2022 5:51pm
Crraigymmmmm
You have exactly the same symptoms as I did. I changed discs 1st then balancing etc. The bushes sorted all the issues
Post #623605 Sat Apr 16 2022 6:39am
Kev H
Thanks for the input and now sorted and yes Dave it was the wheel bearings both changed along with one lower ball joint and steering now good.
Post #623607 Sat Apr 16 2022 12:12pm
