Home > Faults & Fixes > 2010 3.0 TDV6 won’t crank - tale of woe |
Seepee3o Member Since: 05 Dec 2020 Location: Hogsthorpe Posts: 12 |
The problems started with a cracked alloy and resultant flat tyre 5 miles from home. I pulled over emptied the boot and changed the wheel with the space saver. During the 5 miles home I had every fault possible on the dash, EPB, ABS, Gearbox and about 5 or 6 others together with suspension in Lowered mode “ for safety”.I assume due to different radius on the same axle??
Sun Mar 20 2022 9:49pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 485 |
Clean the terminals and posts, grease, reinstall. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Wed Mar 23 2022 11:01am |
Update - solved with a flash of inspiration- I decided to look at the Mega fuse on the positive battery terminal. I undid the positive clamp assembly from the battery and removed the Megafuse plastic cover to discover.the screw clamping the cable was slightly loose and there was movement. I took it apart cleaned all surfaces, tightened with the correct torx adapter and reattached to the battery. Result was the car started with ease and after 1/2 mile driving down the road all errors suddenly cleared completely. I have never seen any posts mentioning this cable connection but would offer as a point to check to anyone having wierd and sudden fault lights for no apparent reason. Removing my battery terminal at the start of this saga probably dislodged loosened the connection further and made everything worse. Lesson learnt¡ 2010 3.0 TDV6 HSE Luxury - Santorini Black - First RRS and lovin’ it |
Sat Mar 26 2022 8:23am |
