Home > General > RSS 2016 7 Seater Auxiliary battery location?
3verycloud
I had my RRS off the road for a few weeks over xmas while I was awaiting a new DPF.
Since it was off the road it's been a nightmare to start and won't turn over.
I've replaced the main better but cannot find the auxiliary battery to replace it... I've had a look in the boot in the rear right compartment with all the other electrics, but it's not there?
It's a 7 seater version and am wondering if someone can point me in the right direction of the Aux battery??
Also is the Aux easy to source?
Thanks in advance!
Post #622074 Sun Feb 20 2022 12:09pm
karlos01
what year is your RRS
Post #622075 Sun Feb 20 2022 12:13pm
karlos01
my friends vouge has the aux battery under the window scuttle below front window
Post #622076 Sun Feb 20 2022 12:16pm
3verycloud
Hi... 2016!
Post #622077 Sun Feb 20 2022 12:16pm
3verycloud
Thanks.... I've checked under the window and it's not there either!
Post #622078 Sun Feb 20 2022 12:23pm
karlos01
other place could be under the passenger footwear below the fuse box
Post #622079 Sun Feb 20 2022 12:25pm
Heremyjill
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Hello,
I do not think the model you have has an auxiliary battery. These were fitted to to MY2014 to MY2015 models. As they were mainly used for the Stop/Start process, the later models (like yours) had a capacitor installed I believe. This was then located on the right hand side of the boot (where the auxiliary battery would have been fitted). "Every Day is a School Day"
Now 2014MY RRS SDV6 AB
Now 2018MY Ford Fiesta ST Line 140bhp
Gone 2006MY BMW X5 3.0d Le Mans
Gone 2001MY BMW 530d Estate
Post #622080 Sun Feb 20 2022 1:24pm
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
Have you tried putting the battery’s on charge? I put mine on a CTEC charger every now and again and the stop start works again. It also reconditions the battery’s and tells you if they are kaput. I do this by using the terminals under the bonnet and does take a few hours to charge up fully but it does charge the main battery and the aux battery too.
Post #622081 Sun Feb 20 2022 1:27pm
3verycloud
Thanks... that may be the case with the capacitor.
Does anyone have a picture of this?
Also, great idea with charging the battery with the terminals under the bonnet. I'll give that a try too.
So, if my model only has a capacitor rather than an aux and the new battery isn't starting the car correctly... it powers up the dash for a short period sometimes starts and other times either just hear the starter ticking and then dies! I have it booked in with an auto electrics garage on the 1st to explore but thought I'd ask if anyone had similar experience???
Post #622084 Sun Feb 20 2022 3:00pm
