Home > Technical > P0486 exhaust gas recirculation sensor B circuit
zenta
Austria 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
hi all,
newbie here. got my car used 8 months ago.
started troubleshooting in my opinion after full service(not related probably) bit sluggish when i hit the pedal
-restricted performance - P00BE trouble code
cleaned and switched the MAF sensors
-still restricted performance - new code P0486 exhaust gas recirculation sensor B circuit
comes almost every day after at least 50km..
any ideas where i should start/what it could be?
would a EGR blank+delate help?
thankful for any replay..
Post #621970 Wed Feb 16 2022 6:38pm
NoExpert
That’s the left side EGR valve. What year/engine do you have? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #622068 Sun Feb 20 2022 9:21am
Do you have the other two numbers that go with that code? as there are four codes that start P0486, although they all seem to mention a possible throttle position sensor fault.
Post #622072 Sun Feb 20 2022 11:34am
zenta
2011 RRS 3.0 TDV6 Fuji White
Post #622439 Fri Mar 04 2022 1:44pm
zenta
no, only those 4 numbers..
Post #622440 Fri Mar 04 2022 1:45pm
