Home > Technical > EGR valve
lkdgndg1
EGR valve
Has anyone replaced the EGR valve on the Range Rover sport TDV8 3.6 , as I’ve got a l/h one to replace and wondering how much of a job is it , the cars a 2009 model , I think I’d sooner replace the valve than delete them as I’ve got the DPF fitted .
Post #621783 Fri Feb 11 2022 7:31pm
stozertom
England 2008 Range Rover Sport TDV8 HSE Lux Java Black
Hi ssc100
I've just recently replaced LHS & RHS egr's & coolers on my 2008 tdv8 3.6, using Britparts.It is fairly complex & tricky but manageable, there's a good thread on Landyforum (must be some on here as well) and some Youtube stuff might help prepare you for the task. I would personally recommend you replace both egr's, use new gaskets throughout, take great care with the cooler to egr fixings (they are stainless steel-non magnetic (easily dropped into the abyss !), take plenty of photos before/during to remember all the connections, keep parts in order of removal/re assembly, decoke/clean out the manifolds (nasty crud it is), double check everything ! Take care & Good Luck.........TomL
Post #621794 Sat Feb 12 2022 8:48am
Disco_Mikey
Given where the valves are situated, it would be wise to do both Thumbs Up
Post #621796 Sat Feb 12 2022 11:49am
lkdgndg1
Hi and thanks for both the reply’s, looks like I’ve got a job when the weather warms up .
Post #621817 Sat Feb 12 2022 8:23pm
Eaters
How did you get on with this?
I have just had my engine warning light come on. Took it to my local indie who plugged in their reader and diagnosed left hand EGR valve sticking. They have reset the codes and told me to take if for a run, floor it and then let it slow down on the overrun a few times in case it was just a bit mucky as this might clear it. The warning light stayed off yesterday. haven't been out today yet... They also mentioned adding an additive to my fuel but I already use Redex regularly. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #627722 Thu Oct 27 2022 1:24pm
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi my brothers RRS same reg as yours had exactly the same problem he purchased Revive turbo Egr cleaner followed the instructions and hey presto no more light and thst was a couple of months ago.He is adamant the car feels better overall after it.I just purchased some myself to run on my 3.0 RRS when I service it as a precautionary measure. Thumbs Up
Post #627729 Thu Oct 27 2022 2:23pm
Eaters
Thanks - I'll have a look Robin
Gone:
MGZTT 190 2.5
Post #627731 Thu Oct 27 2022 4:17pm
DrRob
Have you not considered blanking them physically and electronically? No more issues and cleaner intake.
Bodsy can do both and is mobile....it's what I would do Whistle Visitor from fullfatrr.com
Post #627745 Fri Oct 28 2022 8:36am
Eaters
Thanks Dr. It is part of my thinking. No huge rush as everything is back to normal for now. But I guess it will only be a matter of time..... Robin
Gone:
MGZTT 190 2.5
Post #627746 Fri Oct 28 2022 9:29am
