Home > Faults & Fixes > RRS 09 HSE Transfer case
JordRRS09
United Kingdom 2009 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi All,
I've had a transfer box failure. Now.my question is do these really.need calibration when changed?
TIA
Post #621581 Fri Feb 04 2022 9:43pm
Disco_Mikey
Yes, they do Thumbs Up
Post #621583 Fri Feb 04 2022 10:35pm
Danny.H
Scotland 2007 Range Rover Sport TDV6 HSE Java Black
What sort of damage can we cause if we don't calibrate them? I've switched my module out about 6 months ago and it "seems" to be running fine. Genuine question am I doing untold damage?
It was a used part out of an RRS 07. 2007 RRS 2.7 HSE - Java Black
Post #623656 Mon Apr 18 2022 12:38pm
I doubt it would cost much to get a suitable LR specialist to do the calibration for you. At least you know it's been done. Thumbs Up
As the transfer control module is separate from the transfer box, and the transfer box has sensors telling it whether it is in high or low and the position (and temperature) of the actuator motor, the calibration will ensure that the control module knows what the sensors are saying - "here I am in high", "here I am in low", "here is me locking the diff 100%", etc.
From the workshop manual:
Quote:
Clutch and Range Change Mechanism Calibration
In order for the range change mechanism to function correctly, the transfer box control module must be calibrated to the mechanical dimensions of the transfer box that it is connected to.
    This procedure will need to be followed if one of the following occurs:
    The vehicle is first assembled
    The switch is changed
    The transfer box control module is changed
    The transfer box or range position sensor is changed
    Vehicle or transfer box control module fault has caused the transfer box to revert to an undefined range.
Calibration can be carried out using the service tool or by following this procedure:
    Switch ignition to position II without the engine running
    Select neutral
    Depress the throttle pedal fully
    Press and hold the range change switch for 5 or more seconds to allow calibration to start
    When the calibration is heard to start, the switch and throttle pedal can be released
    Upon adopting high range, start the engine and wait 30 seconds while the first calibration of the clutch in high range is
    done. While this calibration process is in progress, no shifting is accepted
    Switch ignition off and wait 15 seconds
    Start engine
    Perform a range change to low range. Wait 30 seconds while the first calibration of the clutch in low range is done. While
    Range and clutch calibration is now complete.
I have no idea if the calibration can still be done like that, however. 2012 SDV6 - it's missing a couple of cylinders
Post #623665 Mon Apr 18 2022 7:20pm
Danny.H
Thanks for that info. Might give that workshop guide a go tomorrow, failing that she's due her mot soon so I'll get it looked at then. 2007 RRS 2.7 HSE - Java Black
Post #623666 Mon Apr 18 2022 8:21pm
