Home > Maintenance & Modifications > Rear brake backing plate replacement…
Crp
The rear brake backing plates are in need of replacement on my 2012 Sport…
Hearing all sorts of horror stories re replacement….
What would be the cost to have these replaced at the same time as normal rear disc / pad replacement
Chris
Scotland
Post #621547 Thu Feb 03 2022 9:46pm
I believe to change the backplates you have to remove the hubs as well, I don't know if they are available in the UK but you can get a modified backplate kit which is essentially a backplate cut in half which enables you to fit it without removing the hubs, would assume you just need to cut the old one in half to remove unless if falls apart from rust.
https://www.roverparts.com/brakes/kits/LR048812ABP/
Post #621548 Thu Feb 03 2022 9:57pm
Crp
Thanks Col,
That seems like a possible way forward be interested to hear from anyone who has gone down this route….splitting the backplate
Post #621561 Fri Feb 04 2022 10:02am
