Home > Faults & Fixes > Fault code P138E-22
Sween23
United Kingdom 2008 Range Rover Sport TDV6 HSE Rimini Red
Fault code P138E-22
Hi all
Could someone advise what this fault could be. Car runs fine with no issues it seems to be the only fault that keeps coming back.
Ta
Post #620985 Sat Jan 15 2022 9:14pm
First thing to do is check the turbo actuator is loose/free
This can be done thru the passenger wheel arch and a bent coat hanger
If it’s stiff. Use Wynn vvt cleaner
Otherwise sounds like the actuator. Which you don’t seam to be able to purchase without the turbo
Post #620986 Sat Jan 15 2022 10:05pm
