Home > Technical > steering wheel lights
karlos01
hi folks my lights on steering wheel flick din and bright when I turn the wheel only does it on steering wheel not the dash
I'm thinking maybe a loose connection
is the wheel sod of a job to get off or is it worth jut leaving it
Post #620763 Mon Jan 10 2022 6:02pm
it will be the clock spring I expect.
Could well be a warning that other things will stop working soon, e.g horn, cruise control, airbag light on
Post #620766 Mon Jan 10 2022 6:16pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
+1 with Andy K. Highly probable it's the clock spring. Not something I'd try to replace but others here have done so successfully. Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #620767 Mon Jan 10 2022 6:19pm
Easy enough to replace clock spring, just make sure to disconnect battery first and leave for awhile to ensure any residual voltage etc. to dissipate. Can buy tool to release air bag for few quid or a bent metal coat hanger will suffice.
Post #620774 Mon Jan 10 2022 7:45pm
karlos01
is it the sme as removing a p38 steering wheel it was 4 the torx bolts hold the irbag in place
Post #620775 Mon Jan 10 2022 7:48pm
No
Post #620776 Mon Jan 10 2022 7:51pm
karlos01
ah I best swat up on it then 😆
I'm fairly mechanical minded as had p38 so use to working on ranger rovers
need to find a thing like RAVE for repairs
Post #620779 Mon Jan 10 2022 8:09pm
You need a tool similar to this.
&ab_channel=powerfulukltd
Post #620785 Mon Jan 10 2022 8:16pm
karlos01
thanks col for I'll watch the vid brother inlaw has the airbag tool you posted
Post #620789 Mon Jan 10 2022 8:58pm
