Home > General > Pre-Heater disabled |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5007 |
First. I would post over here with more info.
Sat Jan 08 2022 1:31pm |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 |
Hi, the reason L/R fitted the FBH is to help the engine get up to operating temp quicker it also helps the cabin get some heat quicker as well, in stop start traffic in cold weather the FBH can fire up a few times its not just when you first start the car, if its below thresholds it will fire up again to help the engine, so you may get increased fuel use if its not working and increased engine wear (does depend on your journeys!) as said have a look over on D3 for the specific topic you should not have to have it disconnected either after a few faulty runs it will lock out and just not work. Porsche Cayenne 2022 gone Porsche Cayenne 2020 gone Corris Grey HSE Dynamic 2016 gone Ipanema HSE lux 2010 gone Rimini HSE 2005 !! |
Sun Jan 09 2022 5:38pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 949 |
What exactly is the problem with it?,,,, spares are available and the units themselves are not very complicated. 2010 RRS, TDV8
Mon Jan 10 2022 6:03pm |
Hi,,
Sun Mar 06 2022 8:33pm |
