Home > Faults & Fixes > stop vehicle stop safely stop engine
tess
This message sometimes comes up, is to do with the active suspension?
Post #620637 Fri Jan 07 2022 10:42am
Disco_Mikey
Check ARC fluid level. You'll probably be low on fluid due to a leak...
Post #620657 Fri Jan 07 2022 9:10pm
jases4x4
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Santorini Black
I have started getting exactly the same message only when start up and when i restart its gone, i hve had a very slow leak on rear arc some time so i guess i have low fluid will check mine tomorrow.
Post #620660 Fri Jan 07 2022 11:25pm
