Home > Technical > Car won't go into access mode when brakes are engaged
Josh95
Northern Ireland 2012 Range Rover Sport 3.0 TDV6 HSE Java Black
I don't really need to use it, but I will try and raise/lower the air suspension every so often just to make sure everything is working.
Every time I try to lower the suspension to access mode, with either the car put in park or my foot on the brakes, the car detects an obstruction and shoots up into an extended clearance mode.
The car will lower into access mode whenever it is in neutral and I'm not applying brakes, or when travelling at a slow enough speed.
Is this something that is normal, or should I be concerned about it?
I'm a bit timorous of playing about with the suspension too much, as I've heard horror stories of the suspension failing with people on motorways, loosing control of the vehicle and blow outs happening.
Whenever I take my car to get serviced next at a local indie (this is my first time owning a RR) do the mechanics check the EAS components as part of the service, or should I specially request for them to have a look and make sure everything is ok?
Post #619986 Wed Dec 15 2021 1:16am
I really wouldn't take any notice of the horror stories, these are usually, well Numpty down the Pub said "blah blah blah" who has probably never even been in a Sport yet alone owned one.
Mine certainly goes into access mode with the brakes applied and in park, so I would assume you do have a issue of some sort there. Although I very rarely do it that way, usually do it while moving slowly or with transmission in neutral and all brakes off, as work on the basis it allows the suspension to find it's own natural position without loading up the the bushes, well that's my theory anyway, rightly or wrongly.
Post #619988 Wed Dec 15 2021 1:42am
I would say it’s because the park brake is on and fairly normal.
I wouldn’t worry about it.
A suspension calibration may fix it, but. I would leave it alone
Post #619990 Wed Dec 15 2021 4:51am
Make absolutely no difference to mine if the park brake is on or off, it still goes into access mode.
Post #619992 Wed Dec 15 2021 5:10am
When in perfect condition they do
Post #619993 Wed Dec 15 2021 6:19am
Dave-t
Re: Car won't go into access mode when brakes are engaged
Sorry, but what a load of ball cocks.
There is a thread somewhere about the compressor vent outlet becoming blocked which can cause this, cured by drilling a slightly bigger hole, this could be the beginning perhaps.
As Col said, I don’t believe going up and down with brakes on is good engineering practice for the bushes and bearings, it just puts stresses through in the wrong direction and with resistance, far better to be rolling even if only very slightly. Joined the X5 45e club
1994 Defender 90 300 tdi
Post #619994 Wed Dec 15 2021 8:15am
Tyrefitter
Compressor vent outlet will be blocked,I had this problem with a friends sport a few years ago,i removed the filter fitted a new one which had a hole in it,the original didn’t have a hole as it was a early model sport,so I’m guessing LR worked this out & started fitting them with holes in.New filter was only about £8 iirc,I kept the old filter but drilled a hole in it just in case I got another sport in with same problem.
 Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #619995 Wed Dec 15 2021 8:40am
Silverstone
United Kingdom 2012 Range Rover Sport Supercharged HSE Baltic Blue
I concur - mine did the same with the compressor vent outlet blocked. Hopefully the same for the OP. There is no replacement for displacement - W O Bentley
MY2013 5.0 Supercharged HSE L320
Post #619996 Wed Dec 15 2021 9:15am
Still seems a little odd that it only does it in park or with brakes applied as would have thought it had to exhaust air in either case, but this is land rover I guess. Laughing
Post #620016 Wed Dec 15 2021 9:02pm
If it's not going in to access height with the brakes and / or park brake applied, there's a problem.
I'd discuss it with your indie and mention the specific situation that causes the issue. Let them have a look and then discuss again.
Don't "internet diagnose" it. That won't help you in the first instance. It might help later, true, but going i and saying "I've read on the internet that the problem is this, fix it" won't enamour you to your indie, especially if it's still wrong after the work and you're grumpy about it. 2012 SDV6 - it's missing a couple of cylinders
Post #620017 Wed Dec 15 2021 9:06pm
Tyrefitter
You could always remove the filter & see if that solves the problem,when my friends did it I removed the filter till the new one came,all that happens,is you can here the air coming out when adjusting the suspension. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #620018 Wed Dec 15 2021 9:12pm
Josh95
i tried it again this evening. Had the car in park, and the handbrake on. Put it into access mode and it immediately raised up again. I then pressed down into access mode again and it worked?
Post #620025 Wed Dec 15 2021 10:44pm
garrycol
Australia
My guess is that you need to have your suspension recalibrated. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #620026 Thu Dec 16 2021 12:33am
