Home > Faults & Fixes > Restricted Performance, abnormal noises |
Shaun W Member Since: 03 Mar 2020 Location: Dewsbury Posts: 79 |
Could one of the issues be your Intercooler hose is cracked/split.
Wed Nov 17 2021 2:52pm |
lj5000 Member Since: 17 Nov 2021 Location: Nottingham Posts: 3 |
This is something I need to look at however this also happened on one of my LR3s, I didn't get restricted performance but did get a lot of smoke out the exhaust when accelerating hard with that problem. Worth a check if it's given you the restricted performance... Thanks |
Wed Nov 17 2021 2:54pm |
Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 221 |
Had smoke from the exhaust and performance was restricted in my TDV8 earlier this year , took it to my indi who found a split turbo boost hose cheap fix £19, I had feared it may have been the turbos which would have been considerably more. |
Wed Nov 17 2021 3:21pm |
Yes, I am dreading it is turbos but the car is absolutely FINE for about 20mins after starting each day so I think they are working fine.... |
Wed Nov 17 2021 3:24pm |
