Home > Technical > Dashboard swap
Simon_CSK
Dashboard swap
I have a 2007 and 2011 Range Rover Sport both with engine bay fires. I also have a 2008 donor vehicle which I have stripped the loom from.
Of the two project cars the 2007 is the better prospect as it only has 87k on the clock and is a one owner car. I am thinking about updating the 2007 to the 2011 but keeping the ignition lock on the column.
I doubt there will be much difference in the gubbins underneath the dash however there is likely to be differences in the wiring.
I don't suppose anyone knows the implications of this conversion? Current cars
Range Rover Sport HSE TDV8
Range Rover TDV8 Vogue
Range Rover P38 Vogue
Range Rover CSK
Discovery 3 HSE
Post #618442 Wed Oct 27 2021 7:44am
Disco_Mikey
Everything behind the dash is different , whole wiring loom is different, MOST is completely different, ECU's work on a different CAN speed...
Post #618453 Wed Oct 27 2021 12:04pm
Simon_CSK
Ok thanks for the help. Guess I will not be doing that then. Current cars
Range Rover CSK
Discovery 3 HSE
Post #618465 Wed Oct 27 2021 7:00pm
