Home > Wheels & Tyres > 22" 10j Wheels, what size tyre?
Martek
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Stornoway Grey
Hi Guy's
I have 22"10J Wheels fitted to my 2012 Range Rover Sport.
Currently fitted with 285/35/22 Tyres.
What wider size tyre can i comfortably go to on the rears, would like a wider stance.
Thank you Dave.
Post #618153 Sun Oct 17 2021 3:20pm
Tyrefitter
You will get away with 295/40r22 but you need all 4 same size on the RRS’s as they are 50/50 drive. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #618155 Sun Oct 17 2021 4:37pm
Martek
Hi
What about i go 275/35/22 on the front and if they fit 315/35/22 on the rear both will be same 110 height.
And will give the wider stance i am looking for?
Cheers Dave
Post #618180 Mon Oct 18 2021 7:51pm
As profile height is calculated on percentage of width of tyre i.e 3.15x35 =110.25mm 2.75x35 =96.25mm, those sizes will still give you a approximate 28mm difference in diameter. To get near you would need to run 21" rims on the rear.
Post #618182 Mon Oct 18 2021 8:22pm
Should understeer like a supertanker too... 2012 SDV6 - it's missing a couple of cylinders
Post #618184 Mon Oct 18 2021 9:05pm
Martek
Sorry Guy's, don't know why i put 35 ratio twice.
Put wrong size, i meant 275/40/22, so same 110.
Tyres would be 315/35/22 and 275/40/22
Both are readily available sizes.
I'm just intrigued as to whether the rears would fit?
Regards Dave.
Post #618193 Tue Oct 19 2021 11:06am
