Home > Technical > Rear view cam. No steering direction lines
RRS Dave
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Rimini Red
Hi Guys. Just come up to the RRS forum from a Freelander 2. And what a step up it is. Amazing car!!. The car is a 14 plate 3.0 V6 diesel. My first question is regarding the rearview camera. Which works fine. Apart from not showing the reversing lines. I think normally yellow? Does this year/model, not have those lines, or is there a simple fix that either I can set up, or does the car have to go to the main dealer to fix?
Thanks Dave. (In the UK)
Post #618024 Mon Oct 11 2021 6:24am
gogsy1956
Seen a similar post on this before,,, I maybe wrong but not sure if it depends on the type of reverse camera you have,,,, surround type or rear only,,,, surround type has the reverse lines. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #618036 Mon Oct 11 2021 6:27pm
Not sure about the RRS2 but on the facelift RRS1 you can turn various graphics on or off via the screen menu by touching the screen while reverse gear is engaged, as mentioned sure you only have "bendy" yellow lines with surround cameras but as said that is the RRS1.
Post #618038 Mon Oct 11 2021 7:50pm
RRS Dave
Thanks for your help guys Very Happy
Post #618041 Tue Oct 12 2021 6:50am
