![]() | Home > Wheels & Tyres > 275/50/20 Tyres |
Lew White Member Since: 08 Dec 2009 Location: Adelaide Posts: 40 ![]() ![]() ![]() |
Hi.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5062 ![]() ![]() ![]() |
I'm running 275/45 x 21" Wheel/Tyree combination, according to various Tyre/Wheel comparison sites that makes them 781mm diameter, the size you mentioned would be 783mm diam. I don't really think the extra 2mm is going to make much difference. I have been running the 21's for nearly 6 years at least and never had any problems, I even lowered the suspension slightly as well. I fitted a full size 275/45 x 21 rim with a brand new tyre in the spare wheel space and it was very tight and needed a little work with a dremel to smooth some welds off, a easier option may be to get hold of a spare rim with a half worn tyre as it's only a spare, which may make it a little easier to fit in the space I would think. Not sure if the ATR's would be slightly lager diam. though as I am running Pirelli Scorpion Verde all season or something like that.
Thanks Col. Your experience leads me to think that a 275/50/20 might be the way to go for me.
