Home > In Car Electronics > sat nav/tsd issue
kas982
United Kingdom 2005 Range Rover Sport Supercharged Bonatti Grey
sat nav/tsd issue
hello
need some advice, my sat nav is not working ( says no disc ), however there is a disc in the machine. second issue is i'm not sure what i should have installed on the tsd, at the moment i have only the 4x4 info working. i know mine might be a "poverty spec" vehicle but surely it would have phone pairing, trip info etc.
i have added some photos, also found some wires not connected under the rear pass' seat.
thanks
Post #617839 Sun Oct 03 2021 2:02pm
Trip computer is hidden in there. (its active when fitted to the full fat/sized Rangerover)
BT was optional extra. If the steering wheel has red and green phone icon buttons on the side, its fitted.
It requires an extra unit (fitted in the right of the boot, from the factory)
I would fit a 2010 denso facelift display (also fitted to D4) to get nav working
https://www.rrsport.co.uk/forum/topic55655.html
Again people recommend fitted later BT module
P.s I think the wiring plug under the rear seat, is for the rear seat heater
Post #617841 Sun Oct 03 2021 7:27pm
kas982
thank you... will have a look around for that unit, yes steering wheel has the green/red buttons.
Post #617884 Tue Oct 05 2021 1:45am
