Home > Faults & Fixes > Buz
H
England 2007 Range Rover Sport TDV6 HSE Santorini Black
Buz
I have a buzzing noise, coming from the battery area ,any thoughts on this would be appreciated ££££ Chris
Post #617736 Mon Sep 27 2021 11:15am
gogsy1956
Is this all the time or just when the engine is running? . First place I would look is in the fuse box if yours is next to the battery, check that none of the relays are chattering,, put your finger on each one in turn see if you can feel any difference between them. If your old school use the " screwdriver in your ear " method Laughing 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #617741 Mon Sep 27 2021 4:13pm
The ECU sits in a box on the bulkhead behind the battery and the box has a fan to keep it cool. Might be the fan making the buzzing noise. 2012 SDV6 - it's missing a couple of cylinders
Post #617752 Tue Sep 28 2021 8:38am
H
Buzz
Thanks for the reply . Does the fan run on after the car is turned off, it makes the noise for about 20seconds after car is switched off
Post #617791 Thu Sep 30 2021 5:50pm
That could be the EGR valves. They cycle through their range motion to ensure they don't get stuck. They do make a buzzing type sound when they do it.
The ECU fan may continue to run if the ECU is hot, of course, but I'm not certain whether it does or not. 2012 SDV6 - it's missing a couple of cylinders
Post #617800 Fri Oct 01 2021 8:00am
