![]() | Home > General > Steering columb adjustment |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5039 ![]() ![]() ![]() |
someone having the same issue here, but no solution yet
lkdgndg1 Member Since: 15 Jan 2021 Posts: 32 ![]() |
Hi and thanks for the link , yes I’ve the exact same problem and will try to sort it out thanks though |
Hi they mention an ID tool ,what is that and where can I get one from |
RugHead Member Since: 26 Nov 2020 Location: South Yorkshire Posts: 40 ![]() ![]() ![]() |
https://bellautoservices.co.uk/store/iid-bt-tool-gap-diagnostics/
They are £500 |
alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 213 ![]() ![]() ![]() |
[quote="ssc100"]Hi my 2009 sport HSE the steering columb adjustment does not work at all , I’ve tried looking for help with this and all that comes up is with the l322 which is different , I’ve tried all the fuses and plugs I
Hi alfapat my HSE doesn’t have any manual adjustments and is only fully electrical , just the auto/man switch and no manual unlocking lever underneath the column. |
im thinking it may be cheaper to get a specialist to check it for me as those tools are quite expensive . |
Strange that? Maybe depends on age . Mine is a 57 plate , maybe yours is newer. |
Hi yes mines an 09 . |
I though that might slow you down ![]() The autel AP200 WHITE is worth considering for other things. (from £44) Electric column came in around 2007 I think |
Hi Andy and thanks for that , I have an ICarsoft for the Range Rover but can’t justify 500 for the IID tool, well not unless I’m going to use it a lot , I’ll check out the AP200 though thanks . |
