Home > Faults & Fixes > Handbrake loud squeeling
nigelcop
United Kingdom 2011 Range Rover Sport TDV6 HSE Java Black
Hi
Is there anyway I can turn off the warning sound for my epb??
Post #619137 Sat Nov 13 2021 12:11pm
What warning sound are you referring to? any warning sound/light would normally indicate a issue, the most logical thing would be investigate the issue before it becomes a very expensive repair. If it's the screeching noise then based on other members experiences the EBC wants stripping and servicing.
Post #619155 Sat Nov 13 2021 10:16pm
gogsy1956
There is no warning sound as such on the EPB,,, the screeching sound that is heard is the plastic gearing inside the module ripping itself to shreds,,,,. If there was a warning sound for their why would you want to turn it off anyway??. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #619163 Sun Nov 14 2021 5:33pm
duckboy74
United States 2007 Range Rover Sport Supercharged Java Black
Just wanted to chime in.
I've had the electronic parking brake (EPB) sound for some time even after I had replaced the rear shoes.
I ended up ordering a new EPB module and was ready to start the job. Before doing so I did one more Youtube search how to replace it to get familiar. Ended up watching this video and it turned out it fixed my issue. The video mentioned adjusting one side (passenger rear), but I did both sides.
From my experience, you can have the EPB sound (thinking the module has grind itself to death), but actually the rear shoes just need to be adjusted on both sides.
Hopefully this gives more people hope. Replace your rear shoes and readjust them correctly.
Post #619442 Tue Nov 23 2021 4:55pm
